Counter/Timer
取消
顯示結果
搜尋替代
您的意思是:
counter noise on cDaq9178
OK, John, I am getting closer. Thanks for the lead to the "this KB"   However, I am getting something that does not appear to match the content there.  See the attached screen shot where I am trying to create the property channel node. I can create it and select Period-DigitalFilter-Enable, but, the arrows that display are OUTPUT arrows, but, in the "this KB" (arrows right direction)  the arrows are input functions.  What am I missing here?
Should I be creating input or outputs on the property channel node?  The instructions  appear to show inputs, but, I cannot see how to configure them as inputs.
Dave
0 積分
11 條訊息(共 13 條)
2,821 檢視
Hi Dave,
In LabVIEW, the arrows on the right indicate you are reading from the property, and arrows on the left indicate you are writing to the property.
Since you want to set the value of the property (rather than query the current values), you will need to change the property to Write.  You can do this through the right-click menu:
Best Regards,
John Passiak
0 積分
12 條訊息(共 13 條)
2,811 檢視
That works! Thanks.
0 積分
13 條訊息(共 13 條)
2,798 檢視
