Counter/Timer
What does "instance" mean?
I often see the word "Instance" in NI documentation, but, I don't have a clear understanding of what it means.  Can someone please offer a good definition of the word "Instance" as it pertains to Labview?  Here is an example of some documentation that would be more useful to me if I understood the intended meaning of the word "Instance"
"The instances of this polymorphic VI correspond to the I/O type of the channel, such as analog input, digital output, or counter output; the measurement or generation to perform, such as temperature measurement, voltage generation, or event counting; and in some cases, the sensor to use, such as a thermocouple or RTD for temperature measurements."
Does it just mean the occasion of usage? or application?
Dave
(6,356 Views)
When dealing with polymorphics, the "instance" is the exact VI in the polymorphic that is being called.  As an example, I have a polymorphic VI "A".  The polymorphic has two instances, "Foo" and "Bar".  To bring in your example a little closer, when you wire up a string to the input of A, Foo is actually called.  If you wire up a double, Bar is called.  So when I wire up a string to A, the instance that is called is Foo.
Does this make any sense at all?
(6,354 Views)
No, sorry, not really.  What does "instance" mean?  In general, not just related to polymorphics....  It is widely used in the literature on NI.com for many different definitions.  Can you give a specific definition of the word "instance"?
Does "instance" mean VI in general?
(6,349 Views)
Accepted by dav2010
from the dictionary:a case or occurence of anything
I wouldn't necessarily say it generally means a VI.  More like an occurence of a VI.  It gets hard to explain the word without context here.  I say this because when you get into reentrant VIs, an instance is a particular clone of the VI that is in memory.
(6,347 Views)
