Counter/Timer
Synchronizing Two 6602 Cards
I have two 6602 cards connecting with an RTSI cable.  I have succusfully triggered each card individually to count periods on all 8 counters.  However, I need to trigger both cards to count simultaneously on all 16 counters.  Which DAQmx functions should I be using to achieve this?
-Mike
Message 1 of 8
(5,014 Views)
Mike,
The DAQmx function you are looking for to synchronize the two cards is a ArmStart.TrigType.
 Here is a forum post where this same problem is discussed, example code and pictures included!
 This KB talks about synchronizing counters using the ArmStart trigger.
Hope this gets you going!
MatthewW
Message Edited by Matthew W on 07-13-2007 04:17 PM
Message Edited by Matthew W on 07-13-2007 04:18 PM
Message Edited by Matthew W on 07-13-2007 04:19 PM
Message 2 of 8
(5,005 Views)
Thanks for the response, Matt,
Unfortunately I am not using Labview, so vi's do not exactly help me out.  I am coding through Matlab.  I should have specified that.  I have already been using the Arm Start Trigger, though, to successfully trigger 8 counters on a single card.  If I wanted to trigger 16 counters on 2 cards, do I have use an additional DAQmx function, or are the cards able to automatically access each other through the RTSI cable?
Mike
Message 3 of 8
(4,983 Views)
Hi Mike,
Are you using Data Acquisition Toolbox, or MATLAB's generic DLL support to access NI-DAQmx directly?
-Rob
Rob Purser
Manager, Test and Measurement
MathWorks
rob.purser@mathworks.com
Message 4 of 8
(4,981 Views)
I am using nicaiu.dll and NIDAQmx.h to access the DAQmx functions
Message 5 of 8
(4,975 Views)
I think Matthew's post earlier probably has all the info you need, then.  You'll need to look up the C API calls that map to the methods he mentions in the NI-DAQmx C reference, but that's pretty straightforward.
-Rob
Rob Purser
MathWorks
Message 6 of 8
(4,964 Views)
Hi Rob,
From what I read in the above posts and the attached links, I did not see anything referring to triggering two counters on seperate cards simultaneously, only counters on the same card.  Do you use the same calls to trigger two cards that you would for only one card?
-Mike
Message 7 of 8
(4,959 Views)
 Hi Mike,
 To use the RTSI connection between the cards you will have to register the RTSI cable in MAX first.
This article: http://zone.ni.com/devzone/cda/tut/p/id/4322#toc6 discusses how to do that under the Routing Signal Options header.
  Why aren't my triggers working over RTSI?
  http://digital.ni.com/public.nsf/allkb/80E6951BFAD98DE686256D0A003CDC47?OpenDocument
Where is Select_Signal help?
  http://digital.ni.com/public.nsf/allkb/A120195AAAA9222A86256C69007C8B27?OpenDocument
Discussion of triggering multiple cards over RTSI in textbased programming:
  http://forums.ni.com/ni/board/message?board.id=250&message.id=468&requireLogin=False
  Have a great week Mike!
 MatthewW
Message 8 of 8
(4,953 Views)
