07-12-2007 07:26 AM
07-13-2007 04:16 PM - edited 07-13-2007 04:16 PM
Message Edited by Matthew W on 07-13-2007 04:17 PM
Message Edited by Matthew W on 07-13-2007 04:18 PM
Message Edited by Matthew W on 07-13-2007 04:19 PM
07-16-2007 07:57 AM
Thanks for the response, Matt,
Unfortunately I am not using Labview, so vi's do not exactly help me out. I am coding through Matlab. I should have specified that. I have already been using the Arm Start Trigger, though, to successfully trigger 8 counters on a single card. If I wanted to trigger 16 counters on 2 cards, do I have use an additional DAQmx function, or are the cards able to automatically access each other through the RTSI cable?
Mike
07-16-2007 08:12 AM
07-16-2007 11:01 AM
07-17-2007 07:57 AM
07-17-2007 10:16 AM
Hi Rob,
From what I read in the above posts and the attached links, I did not see anything referring to triggering two counters on seperate cards simultaneously, only counters on the same card. Do you use the same calls to trigger two cards that you would for only one card?
-Mike
07-17-2007 04:21 PM
