Counter/Timer
Pulse output flow meter convert to gallon per minuted
I have 4 pulse output flow meters
https://www.omega.com/pptst/FTB4600.html
all the flow meters connected to NI 9361 to get my frequency readings using the daq assistant. I will need convert my frequency readings to gallon per minutes. The only conversation factor I have from my flow meters is 75.7 pulses/gallon. Any ideas on how I can use that?
(3,125 Views)
Accepted by topic author leq12
Hello leq12,
Do you have a specific equation that you would like to use? If so I can help you with the implementation of it.
Marina B.
Technical Support Engineer
www.ni.com/support
(3,081 Views)
