Counter/Timer
PWM with CompactDAQ 9174 on a DO-Module
Hi all
We did a regulation of peltier elements with PWM with a cRio over FPGA on a DO-Module 9477.
We have now a small project with a CompactDAQ 9174 where we would like to regulate such peltier elements. The Frequenze should be at least 5 kHz.
As I found in the forum and the examples, with the intern counter/timer of the cDAQ9174, it is possible to generate a digital pulse train and with the duty cycle  also a PWM.
e.g.:
http://forums.ni.com/t5/Counter-Timer/Counter-Output-with-NI-cDAQ-9188/m-p/2218208#M10898
http://digital.ni.com/public.nsf/allkb/ADFC4DD8C9690232862575B70079FBD4
What I could not found, is a way to get a generatet PWM-signal out of the intern cDAQ to a DO-Module (S-Serie) such as NI7477. And I do not see the way to do it.
I have to mention, that I'm not a top-programmer, and I'm sure, that there is somone out there, who already has done this.
Thanks in advance for help
Hannes Wydler
(7,048 Views)
Hi Hannes,
maybe this can help you.
How to use internal counter of cDAQ 9172 to measure PWM and generate frequency ?
http://forums.ni.com/t5/Digital-I-O/How-to-use-internal-counter-of-cDAQ-9172-to-measure-PWM-and/m-p/...
They use a similar (not the same) assembly as you are doing.
Abduelkerim
Sales
NI Germany
(7,033 Views)
Hi Abduelkerim
Thanks for replaying
As far as I see, the forum discussion you mention, talks about measure PWM (Digital IN).
I found an other forum input (how to pwm out on NI-9477):
http://forums.ni.com/t5/Digital-I-O/how-to-pwm-out-on-NI-9477/td-p/624448
There Application engineer Samantha says, the NI9477 is not a "corelated" digital module and therefor it cannot link to the backplane counter of the cDaq. Others DO-modules could do that (like 9401).
But what we need is the high power of the 9477 (1 Amp per channel - I would connect 3 outputs together for my need of 2.5 Amps).
I don't find in the specifications of the different DO-modules if they are "corelated" modules.
It seems, it's not possible what I want to do - a simple direct mode with the cDAQ to supply and regulate peltier elements.
Hannes
(7,021 Views)
Hi Hannes,
sory for late reply.
I would suggest you to call at NI Germany (Phone: 089-7413130)
My colleagues from the technical sales department will help you finding a proper module for your assembly.
Abduelkerim
Sales
NI Germany
(6,942 Views)
