12-29-2007 06:18 PM
12-31-2007
12:27 PM
- last edited on
02-07-2024
11:57 AM
by
migration-bot
Hello CR,
Welcome to the NI forums! I am a bit unclear as to what you might need the 5V power supply for. The PCI-6601 draws its power from the PCI bus, so it does not need any external power, and the CA-1000 should not need any external power either (it draws power from the PCI-6601). I think it uses the 5V pin on the PCI-6601 connector for this power, but I am not sure about this. Could you please point me to the documentation that shows you need an external supply?
As far as what NI sells, we provide third party power supplies with our devices that do need external power. We do not, however, make the type of power supply you are talking about. We do make a programable DC power supply (the PXI 4110), but I think that is beyond what you are looking for.
I hope this helps, if you show me where you saw you need a power supply, I'll take a look at it.
01-01-2008 02:30 PM
01-02-2008 09:28 AM
01-02-2008 02:14 PM
| Line | Part Number | Description | Unit Price | Qty | Total Price |
| 1 | 184737-01 | BNC Connector Panelette, CA-1000 Style Enclosure | $ 25.00 | 2 | $ 50.00 |
| 2 | 182482-0R25 | R6868 Low-Cost, Unshielded Ribbon Cable, 0.25 m | $ 49.00 | 1 | $ 49.00 |
| 3 | 185378-01 | Dual Toggle Switch Panelette Assembly for the CA 1000 Enclosure | $ 50.00 | 1 | $ 50.00 |
| 4 | 185376-01 | Four-LED Panelette Assembly,for the CA-1000 Style Enclosure | $ 30.00 | 1 | $ 30.00 |
| 5 | 777664-01 | CA-1000 Connector Accessory Enclosure |
01-03-2008
01:40 PM
- last edited on
02-07-2024
12:01 PM
by
migration-bot
CR,
I would take a look at the CA 1000 installation guide to make sure that you have everything you need. It appears that the only thing you are missing is a connector block. From comparing the installation guide to the PCI 6601 product page, you have two options for this: The SCB 68 and the CB-69LPR.
With that and the cable length (which you already discovered), you should be good to go. In the future, I would strongly recommend calling one of our sales representatives. They are very good at making sure you have everything you need (and only what you need).
01-03-2008 09:58 PM
01-10-2008 09:27 AM
01-10-2008 01:11 PM
