Counter/Timer
NI6003 counter become half num when write do
Dear all
I use labview to try write an counter
if only run counter task,the counter value is correct value
and i add the do task,the counter value also corrct
but when i write true or false to DO task
the counter value will become half of original value
and the value will more jitter in each loop
original one loop about 1195 ~ 1205
after write value to DO  then one loop about 575 ~ 625
pleae help me
device:NI-6003
counter:P2(PFI0)
DO:P1(Line 0)
(1,394 Views)
please attach the VI you're using for us to guide you
Santhosh
Soliton Technologies
(1,370 Views)
