Counter/Timer
NI 9361 FPGA configuration
Hey Mike,
Did you hear anything back from NI about this issue?
Mike C
Message 11 of 18
(3,194 Views)
Hi Mike C,
At this stage it appears to still be with NI senior TSE and FPGA dev teams.
I understand that they are looking into likely links between particular cRIO chassis (904x vs 905x) types as well as CompactRIO driver versions.
No resolution as yet.
If you have any additional info to provide with regards to your specific case, including what hardware you are using, I'd be happy to pass onto NI.
Cheers,
Mike
Message 12 of 18
(3,166 Views)
Hey Mike,
Originally I tried this with a cRIO-9045, NI-9361, NI-9234, NI-9213, and NI-9220, running RIO 19.5.  The FPGA execution hangs right at the point of accessing any I/O node on the 9361 (i.e. Stop, Start, Digital Logic Threshold, Terminal Mode) or trying to read data.
I just tried it on a cRIO-9057 with the same card load & RIO software and see the same situation.
We have pretty much given up on the NI-9361 and moved to other DI modules, mostly NI-9411, but that has plenty of it's own issues.  I really wish they had a DI card with the same configurable electrical interface as the NI-9361, but that just presented the inputs to the FPGA where I can use my existing code that I wrote for the NI-9411.
I'm definitely interested to know if you find out any information, as we have some new projects upcoming that I need to spec hardware for.
Mike C
Message 13 of 18
(3,126 Views)
I realize this is more than a year old, but we just ordered an NI-9361 and we are planning on using it in FPGA mode. Is this still an issue?
Message 14 of 18
(2,831 Views)
Hi all,
Apologize for inconvenience caused but the 9361 issue now is fixed with the latest cRIO driver that is compatible with LabVIEW 2020. You can refer to the cRIO version that is compatible with LabVIEW in the link below.
CompactRIO Device Driver and LabVIEW Version Compatibility - NI
Gus
NI Technical Support
Message 15 of 18
(2,338 Views)
Hi Gus,
Thank you for confirming this issue has been addressed.
While the system has already been deployed with a work around, if we do get a chance in the future to test, we will post the outcome.
Appreciate the update.
Michael
Message 16 of 18
(2,334 Views)
Hi Gus,
Just to confirm, the version with the fix is NI CompactRIO 2023 Q2?  Want to make sure I'm testing with the correct version.
Mike
Message 17 of 18
(2,317 Views)
Hi Mike,
Yes, the fix is included from CompactRIO driver version 20 onwards. So 2023 Q2 would also include the fix.
Gus
Message 18 of 18
(2,272 Views)
