Counter/Timer
Maximum Frequency on PCI-6024E
Hello, I'm just wondering what is the maximum frequency can PCI-6024E hold?
My sensor's range is .016KHz - 16.6665 KHz, if this is too much, can I just use
a divider to cover what is max limit of the card?
Thanks!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(3,534 Views)
200Ksamples/sec on a single channel, per the specs:
https://www.ni.com/docs/en-US/bundle/370719c/resource/370719c.pdf
For optimum accuracy, sample at 5-10 times the highest frequency component of the signal if possible (minimum of 2x per Nyquist), that would be 166.6Ks/sec rate max which is still within range of the card.
(3,527 Views)
