Counter/Timer
Error 200279 caused by timer code
After adding a timer code to a larger VI that uses a cDAQ, upon trying to save the data the system VI would freeze the analog input data gathering and after pressing the stop button would return with the Error 200279. I've provided an image showing the overall section and a close up of the timer code
Overall
Timer
(3,410 Views)
Hey I have a few follow-up questions:
1) What kind of data are you collecting?
2) Which cDAQ and modules are you using?
3) At what rate are you trying to collect data?
(3,367 Views)
