01-27-2018 09:47 PM
Hi all,
I am trying to use the PXI6608 to generate precise pulses. Is it possible to connect the PXI6608 to the BNC2110? I have both, and I am using the cable RS6868 to make the connection. However, the power light indicator is not lighting. Does anybody have an idea about the problem?
Thank you,
JJJJeb
01-30-2018 09:24 AM
Hi JJJJeb,
I think you may find this page very helpful!
Cable and Accessory Guide for 66xx devices:
http://www.ni.com/product-documentation/53086/en/
From this page we can see that the 6608 looks like it works with the BNC-2121 and not the BNC-2110
01-30-2018 11:26 PM
Hi Dane,
Actually, I bought the PXI6608 and the BNC2110 as a recommendation from a NI engineer.
I realized it is possible to feed the BNC with 5 V from an external source. However, that is not convenient.
In a simple way, I would like to generate a very precise pulse in time in order to control a FET relay. The problem is the PXI6608 manual presents too many concepts that I am not familiar with. So, I have a simple application, and it seems to PXI6608 is really useful for that. However, I do not know how to start. Do you have any recommendation in this regard?
JJJJeb
01-31-2018 02:42 PM
For getting started you may consider looking at digital output and counter output examples that are included in DAQmx.
There is an article about where to find examples:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9DUSA0
02-02-2018 11:55 PM
Thanks.
I will check this out.
JJJJeb
