Counter/Timer
Buffered gated event counting
I need to do buffered gated event counting.  I was hoping to buffer counts with a pulse train that acts as both a sampling clock and an active low pause trigger.  However when I try this I get an error -200145  "Measurements: Pause trigger is only valid for event counting if sample clock is not used".  I am able to do unbuffered gated counting but I prefer to be able to display a graph where each data point is the number of events collected during each high gate.
I am working in LV 7.1 with NIDAQMX 8.7.1
Here is my test vi.  In the second frame there is a constant for a case statement that switches 1 sample and N samples.  I am using a an external function generator to create the pulses I count.  The final version will count pulses from a PMT.
(4,269 Views)
I believe you need to use Two Edge Seperation to perform the task you are looking for because the Pause Trigger is not supported.  I would recommend you check out this KnowledgeBase article.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(4,254 Views)
