Components
Queued Message Handler (QMH) and Asynchronous Message Communication (AMC) Reference Library
Thanks Christian, and also thaanks to DaveNShelby for his suggestion.
tstand
Message 71 of 104
(9,293 Views)
Hello
I wanted to try AMC and trying to install it via VIMP, it adds 2 more packages to install NI String Tools Library 2.0.0.5 and NI Keyed Array Library v2.0.0.11 but they failing to install, Labview 2014 32bit, Windows 7 64bit
error message:
Main Package Name: NI String Tools Library v2.0.0.5
Package Name with Error: NI String Tools Library v2.0.0.5
Error Message: VIPM could not install the package ni_lib_string-2.0.0.5 .
Error Code: 8
Error Source: Open/Create/Replace File in ZLIB Read Compressed File__ogtk.vi->ZLIB Get File__ogtk.vi->ZLIB Extract File__ogtk.vi->EED56FA0C4F55E77EEBE36176CE1C33B->7773F18C47B7FC71CA4BAECE7A2EA962->OGPM Class.lvlib:BF046E12330E3D901A9FA815497F26CC->OGPM Class.lvlib:968239FABAFA58D305528EF3DD4CE1AD->1ECB61166404ABCF592B9976749FE772->VIPM Main Window.vi<APPEND>
C:\ProgramData\JKI\VIPM\cache\ni_lib_string-2.0.0.5.spec
the same with both libraries
Message 72 of 104
(9,261 Views)
Wojciech,
Please try running VIPM with Admin privileges in Windows. Most likely VIPM is not able to create some of the temprorary folder/files necessary during unpacking and installation.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 73 of 104
(9,240 Views)
Thanks you very much
it helped
*cheers
Message 74 of 104
(9,228 Views)
The source code for the Asynchronous Messaging Communication library has been migrated to github for source code control and issue tracking.
Source: https://github.com/NISystemsEngineering/AsynchronousMessageCommunication
Issues: https://github.com/NISystemsEngineering/AsynchronousMessageCommunication/issues
Github will contain the latest version of the source code as it is being updated. We will continue to build and publish released versions of AMC in the Reference Design Portal and the LV Tools Network VIPM repository.
Bug reports and feature requests can be submitted in this thread or directly in the Github issues list.
authored by
Christian L, CLA
NI - Austin, TX
Message 75 of 104
(9,194 Views)
Just a question for the understanding of code. In the 'AMC Multiple Local Processes.lvproj' project, boolean process data is transfered beetween two local processes. This works vice versa between 'process1' and 'process2'. I realized that the 'Send Message to Local Process.vi' obtains the queueu to the 'other process', and 'Send Message to Current Process.vi' than sends it to the queue obtained before, but than the queue is released.
How can the queueu still work on the other process, if it is released here. Do I have a general missunderstanding of the queue functionality ?.
Jörn
Message 76 of 104
(9,136 Views)
Indeed a missunderstanding of queue behaviour. After further reading I found the answer here.
Message 77 of 104
(9,116 Views)
I've been trying to get the AMC Ping Dispatcher function to work. I can't get a response from my remote CRIO system. I know that the dispatcher is running on my remote system is working becasue I can send commands to it.
I belive that both Ping Dispatcher and Send Network Message both use UDP which leads me to think that it's not a firewall or routing issue.
I've attached a test program that demonstrates the problem. It can send two commands which both work. The Ping command however doesn't work.
Any thougts as to what I'm doing wrong?
—Ben
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
Message 78 of 104
(8,932 Views)
Hey Ben,
I've run into this problem recently too. I don't think you're doing anything wrong, I think it's an issue with the dispatcher. Let me take a look at it. I'll post back when I have an update. In the meantime, you could use STM if you need a workaround.
Cheers,
Ian K.
Software Developer
Data Ahead AG
Message 79 of 104
(8,905 Views)
     Apparently it's a known issue.
https://github.com/NISystemsEngineering/AsynchronousMessageCommunication/issues/6
I'm just using the regular old DOS Ping to detect if the RT system is there. It's not ideal since it doesn't show that the application is running. It's only really aproblem in devolpment though.
—Ben
—Ben
Use Power Requests
Message 80 of 104
(8,891 Views)
