Components
Queued Message Handler (QMH) and Asynchronous Message Communication (AMC) Reference Library
I'm attaching a slightly updated version of AMC packaged as VI packages, to be installed with VI Package Manager (VIPM). The community version of VIPM is a free download from JKI Inc. and is the framework NI uses for content in the LabVIEW Tools Network.
http://zone.ni.com/devzone/cda/tut/p/id/12397
http://jki.net/vipm
There are three packages as AMC has dependencies on two other packages of VIs.
The main difference in the updated version of the AMC library is that the VIs are now contained in LV project libraries.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 21 of 104
(13,825 Views)
Thanks, I think I managed to install those ones now. I also have the same problem with flexsignal_112. Can you help me with that one too? Actually my goal is to be able to run the "Data Acquisition Reference Design".
Message 22 of 104
(13,816 Views)
For FlexSignal the Zipped version of the distribution (flexsignal_112_zipped.zip) allows you to extract the VIs directly and place them in your LabVIEW user.lib folder.
authored by
Christian L, CLA
NI - Austin, TX
Message 23 of 104
(13,809 Views)
Ok, thanks. Now I just miss two files.. 'svc_Engineering Units Text Ring.ctl' and 'svc_engineering Units to Unit Label.vi'. Where do I find them?
Message 24 of 104
(13,800 Views)
This is a cross linking error with one of the Sound and Vibration toolkits. Please replace these Vis in your code with the corresponding VIs in the following folder in the FlexSignal code.
C:\Program Files\National Instruments\LabVIEW 2009\user.lib\FlexSignal\Utility\Scaling to EU
authored by
Christian L, CLA
NI - Austin, TX
Message 25 of 104
(13,782 Views)
Hi Christian,
I've built an application using AMC and I'm generally happy with the package.  Two problems that are vexing me right now are:
1) Spaces in the Keys and Values in the Message Attributes are replaced with underscores when sending a message over a network (Send Network Message), but not when sending local messages.
2) No message is sent and no error generated if I try to send a flattened xml string over the network.  Again, this does work when sending local messages.  (I'm flattening objects to xml strings to pass to my RT target).
These problems kinda ruin the abstraction of the package as messaging strategy that works between local VIs breaks when moving the application to a network.  Any ideas for workarounds or for what might be the cause of this behavior?
Thank you very much.
-EDIT-
Whoops!  Just saw that Nate had asked the same question on the first page of the thread!  Does the last update you posted fix this problem?
CLAD
Message 26 of 104
(13,368 Views)
I found a workaround for sending xml strings in the value field over UDP.  Basically, I noticed that the most consistent error when sending xml strings was that the "receiver" field would come up blank after the amc_Parse XML.vi tried to parse a message with a xml string in the value, so I use that as my indication that there is an xml string.  If the receiver is blank, I just remove the value string from the original message xml string, parse the remaining message using the same method as amc_Parse XML, and add the raw xml string to the resulting message.  This allows objects flattened to xml string to be send using AMC as long as they are only in the value field.  If an xml string is sent in any other field, this fix behaves the same as the original Parse XML vi.
CLAD
Message 27 of 104
(13,357 Views)
my question is, when will you release a version of the AMC reference library with a working acknowledge function?
At the moment you have to control by yourself whether a message receives or not.
best regards
Norbert Schnitzler
Message 28 of 104
(13,308 Views)
Norbert,
Adding an Achnowledge option to the Send Message is one of the features we have on our list to add to AMC, but we do not have a defined timeline when we might be adding any specific feature.
I hope to release an updated version of AMC by August, but that is always limited by other responsibilities we have in the Systems Enigneering group at NI.
authored by
Christian L, CLA
NI - Austin, TX
Message 29 of 104
(13,297 Views)
testingHotAir,
Thank you for your feedback and posting an updated version of the code. The error is due to the encoding of the messageinto XML for network transfer. Wrapping your XML into the XML of the AMC message is causing the error on the receiving end in the parser.
I will add this to the list of features to add to AMC to be able to handle XML in the value and attributes fields.
Replacing spaces with underscores is also related to the XML formatting, and I will take a look at making this more consistent between local and network messages.
authored by
Christian L, CLA
NI - Austin, TX
Message 30 of 104
(13,296 Views)
