Components
Generic Configuration Editor (xCE) Reference Example
Dear all,
I'm very interested in xCE configuration Editor.
I'd like to personalize the xCE in order to have the possibility to change programmatically some attributes of the node as for example description and movable. I need to save this "modification" to the xml file in order to have the possibility to load them again.
I've done some test with the Description attribute and everything works well: I change the description at run time, saved the xml and when I load it again and the description was present.
I've done exactly the same think with the Removable attribute, but the change is not been saved in the xml file and so not loaded.
Effectively the xml file doesn’t contain all xCEData Node attributes. Is there a possible workaround.
Thank you,
Paolo.
Message 21 of 36
(13,473 Views)
Probably solved modifying:
  • saveDataNodeBegin.vi
  • loadDataNodeBegin.vi
including also the Removable attributes.
Message 22 of 36
(13,471 Views)
I'm glad you were able to figure where to change the code. Did the change work for oyu?
Brian K.
Message 23 of 36
(13,462 Views)
Yes, It's working. Now I'm able to save the "Removable" for all nodes.
Thank you,
Paolo.
Message 24 of 36
(13,458 Views)
This reference design looks very usefull to me!
I was wondering if a getting started guide/walkthroug is available. (Cannot find it in the source.zip)
thx,
Ben
Message 25 of 36
(13,427 Views)
Unfortunately I was never able to make a walk through (had to work on my day job). In the article it talks about "The Tag Configuration Editor was designed to aid with configuring a machine control architecture. The Localization Configuration Editor facilitates the need to add multi-language support to Human-Machine Interfaces (HMIs). Both examples provide source code built upon the xCE and demonstrate what functionality is included." You'll find links there. They are my examples.
Brian K.
Message 26 of 36
(13,419 Views)
Hi Brian,
Thank you for this xCE library.  I have used it to make a sCE (Simulation Configuration Editor).  Defining, ordering and running some simulation modules in the UI.  It works very well.
Alex. P.
Alex.P.
Message 27 of 36
(13,322 Views)
Hi
I would like to access the variant variable "key-value pairs" in "LabVIEW 2015\vi.lib\NI\Configuration Framework\serializable configuration\NISE_CEF_serializable configuration.lvclass". I would like to have an accessor method for the variable itself to read the complete configuration (generically) without knowing the keys. Right know I'm forced to use a workaround with the functions "to string.vi" and parse (similar like within the function "from string.vi") the output "data" to get (and display) all the key-value pairs.
Please find attached the snippet of the "workaround".
Best regards
Markus
Message 28 of 36
(10,728 Views)
Hi Qsi, I created the issue for this in github:
https://github.com/NISystemsEngineering/CEF/issues/89
It will be included in the next build of CEF, which we will update this week or next.  I created a property for read only and gives you the key value pair as a 2d Array.
Also the forum thread for CEF is: http://forums.ni.com/t5/Development-and-Deployment/Configuration-Editor-Framework-CEF/td-p/2730619. The link pointing to this tread in the whitepaper was wrong, and I just updated it.
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
Message 29 of 36
(10,708 Views)
Hi Benjamin
Perfect. Exactly what I need. Thanks a lot.
Best Regards
Markus
Message 30 of 36
(10,694 Views)
