Components
[Deprecated] SPI Digital Waveform Library
hi David,
 i have couple questions here...
  1. what is the range of SCLK frequency this module will support??
  2. what is the exact ratio need to be set between SCLK and sample rate??
Please clarify...
Message 181 of 200
(6,179 Views)
I am using SPI waveform library for working with HSDIO-6548. I have sent 24 bits of data to one of the customer device. The device is working great. Now the problem is I have to send 384 bits of data to the customer device for burst read and write . Can you help me with some code so that I can send these number of bits to HSDIO using SPI waveform library
Message 182 of 200
(5,989 Views)
Dear David,
I would like to know if there is a way to implement sequential byte send to a single slave with variable CS idle?
I attached below the desirable timing diagram.
timing diagramtiming diagram
Thank you in advance
Afonso Plantes
Message 183 of 200
(5,981 Views)
Never mind, I have already solved it.
Message 184 of 200
(5,954 Views)
how can we control SS/ chip select line .. in SPI using HSDIO:
Is there any chance of making chip select (High) de-assert at middle bit of particular transactions without modifying the behavior of other signals (sclk, mosi, miso) in SPI Communication using HSDIO.
We can't help everyone, But everyone can help someone Smiley Happy
Message 185 of 200
(5,872 Views)
is this SDW can be used with NI 9402. David mentioned that
"We can only use the SDW waveform with a clocked digital I/O device"
I am really new with the labview and DAQ. please give me some advice
thanks
Message 186 of 200
(5,765 Views)
Hi Plantes,
Can you share with us how to set the CS idle time?
Message 187 of 200
(5,718 Views)
If you just want to send SPI data to a device (digital pot for example) the a 6509 works fine providing you don't need to send all the data very quickly.
In Labview configure a 8 line port as an output, use 3 of the lines for enable, clock, data. If there are 8 bits of serial data (plus start stop bits) to be sent, then make a sequence of 8 port writes (plus start stop). Then for each of the port write set the:
clock high & data (bit 1 value), write to port
wait a few mS
 clock low & data (bit 1 value), write to port
wait a few mS
The repeat for the other bits.
As its a port write then the clock & data will be in sync. It may take some 60mS or more in this example to do the complete write, but it does work.
Message 188 of 200
(5,652 Views)
Hi rioriorio
I just changed SPI timing (ticks).Idle. Now, I can have differents CS Idles for my MOSI array.
Message 189 of 200
(5,644 Views)
Thank you Plantes
Message 190 of 200
(5,638 Views)
