Jambhekar Automation Solutions, Pune (India)
Email: tushar@jambhekar.com
Tushar Jambhekar
Location | Pune, India |
Contact | Tushar Jambhekar |
Meeting Details | Weekly Meetings, Open to Anyone |
Experience Level | All Experience Levels |
QuickAccess is an utility inspired by Quick drop. QuickAccess allows pogrammer to perform routine tasks in more efficient way. For performing a particular operation,programmer selects all the involved block diagram objects on which operation will be performed.
After selecting the objects user presses certain key combination (CTRL+ALT+Space). The QuickAccess then analyzes the selection and allow programmer to perform all valid operations for particular selection. QuickAccess supports auto completion and list has context of currently selected block diagram object(s)
All QuickAccess Commands are plugins and hence adding new commands is possible.
GOOP is not used to keep application simple. Also this project will require many touches here and there to make it fullproof professional utility. however I have deliberatly not applied those touches as the aim is to keep it as example (So it should be simple)
Though this project is developed by me. I was heavily influenced by quick drop and JKI RCF during design of QuickAccess, I belive QuickAccess is a wonderful fusion of GUI from quick drop and logic from RCF
Open Main Dialog.vi in Source Code\Front Panels folder
For more detailed information about how to use QuickAccess see video attached below
Main Front Panel:
Main Block Diagram:
Note: Main Utility is Available in QuickAccess.zip
03-03-11: Enum Constant related plugins added in EnumConstant.zip (Extract these in QuickAccess plugin Directory)
I am impressed! Really good idea! This could help in laborious task like cleanup, confirming with coding rules etc. Like that!
much of the credit goes to "darrens weekly nuggets" which talked about quick drop.
And i was thinking how i can apply it for n number of other tasks i am doing...(mainly adding so many cases to the state machine case structure)
it started from there and now almost every day i see something which can be a potential plugin for quick access...
unfortunately i am not getting much time to develop those plugins...
Thanks Lul
Great Great Great!!!! I absolutely loved it
Thanks Tushar, for sharing magnificent idea I am very impressed!!!
Thank you very much krunal...
can you please rate me for this entry...
and also help me to sprade the word?
the comments and ratings are really important for me to go to next round...
Also i would like to hear from all of you which task we can add in this utility to make it more usefull.
I hope this code challenge will not be the end of this utility...but the beginning...
Just thinking along the function line where I see this saving time....I think a plug in for editing enum list would be great. It's saving a little bit of time but I would definitely use it.
Truely Impressive Tushar, way to go, Nice utility
Hi Grant
I have just created two plugins.
I dont know whether i should update the plugin files here or not, as i have already submitted my code.
Thanks Justin
You can just edit the document and add it on as an extra file. The votes and everything just go for your overall example and not each individual component. Appending this document will make sure that everyone sees the plugin and uses it.
@Grant : You asked for the enum thing? You got it!
That's the thing I love about Tushar! The work he does, as reflected from his example, is truly impressive and thought out of the box! Even though he is competing against me in this contest, he is my "guru" from whom I've learnt lots of labview stuff (my favourite user group affiliation is the same as his ). This is "just one of his idea" he has shown us from the many ideas he has..... Nice one Tushar!
Excellent !!!!!!!! Its really Greate idea tushar.
I am Impressed. You always finding out the Creative solutions..........
Very Nice ........
Thank you very much parag.
@Suvarna: thank you suvarna.
@Grant Heimbach: Also i am thinking to create one more plugin which will sync the enum and a CaseStructure. This will be useful for all those State Machine users who prefer enum instead of strings. i will upload it as soon as i am done.
It's really nice application. As always do, you came up with innovative idea. This is a brainstorming example for me to work on.
