The 32-bit RISC ARM processor architecture developed by ARM Limited is
widely used across many embedded designs due to its low price, low
power consumption, and wide variety of peripherals for many of the
major silicon vendors. Today, the ARM family accounts for more than 75
percent of all 32-bit RISC CPUs. You can use the NI LabVIEW Embedded
Module for ARM Microcontrollers for programming ARM microcontrollers
with the RTX embedded operating system.
This tutorial offers a general outline for targeting LabVIEW code to
any custom ARM target by presenting an example of how LabVIEW code was made to
execute on the Phytec LPC3180 ARM9 microcontroller. This tutorial will cover the 4 steps necessary to port LabVIEW code to an ARM microcontroller:
Integration of LabVIEW and KEIL Toolchains
Implementing Elemental I/O
Porting the RTX Real-Time Kernel
Integrating the Real-Time Agent
To learn more, continue reading the LabVIEW Embedded Module for ARM Porting Guide.
I've only recently started to use LabVIEW for ARM but I found the tutorial a little difficult to use purely because there were factual errors in it which after 3 years should have been corrected. A little dissapointing!
I'm going to document my progress as I work through the issues I've stumbled across in the hope that others will benefit.
Could any one share the LabVIEW Embedded Module for ARM Porting Guide.pdf
The link is invalid now.
