Certification
Is this a qucik and satisfactory method for CLD error handling? (see image)
http://i.imgur.com/IiI8D1w.png
with reference to: http://i.imgur.com/TyNVWQX.png (from success package document)
Is this too simple an error handler setup?  Assuming non-catastrophic errors are taken care of before leaving any case in my qsm?  An error is only acceptable during debugging isnt it? (unless instructed by requirements?)
I'm trying to think of ways to save some time as I've been working so much I let my test date creep up on me...  Smiley Sad
(5,482 Views)
Accepted by topic author plyons.gks
In the real world, yes.  For the CLD, that is a minimum to get the points.  Just throw down the Simple Error Handler to show the error dialog and you have "handled the error".  If the spec does not say how to handle the error, stop the loop(s) and show the error dialog.  If you are given a spec of how to handle the error, do whatever you are told.
GCentral
(5,471 Views)
Thanks for the confirmation!    ...I just had to hear it from one of you guys
thanks again
-pat
(5,467 Views)
