Certification
Confused by folder structure of CLD exam that I just took.
I took the CLD earlier today and was a little confused about the folder structure. I won't say the exact device that was on my exam, I'll just call it a "Boiler" like one of the sample exams. Please see the attached picture for better explanation of the folder structure than I know how to describe with words, I may not be recalling it exactly but it captures the important part. Essentially, I got nervous that I did all my work in the folder that wasn't going to be graded so I copied & pasted my solution folder to the parent directory of the other "Boiler" folder, and I'm terrified of the results if I selected "skip" instead of "replace" same filenames when it did the folder merge. BUT, WHY was there this confusing folder structure with TWO solution folders and NO explanation for where the solution was "supposed" to go?? Is one supposed to be a backup? If so, why not put it inside a "BACKUP" folder and make it obvious? Most importantly, which is the correct folder?
Message 1 of 1
(844 Views)
