Certification
CLD Exam Front Panel
I will take the CLD exam in two days and I would be grateful if anyone could help me in these two questions:
1/ Do I have the ability to change a Cluster from the given UI into a Typedef?
2/ In addition to Tip strips, Is it recommended to add some comments on the front panel or not?
Thank you very much!
(4,080 Views)
Accepted by topic author hichem55
Hello hichem55,
1. Yes, you can change the cluster into type definition.
2. Yes, It will be better if you can comments on the front panel also about the application working But not necessary as far as i am concerned.
Hemant
(4,058 Views)
Thank you very much.
(4,042 Views)
