Certification
CLA Auto-populating folders in projects
Why are Auto-pop folders "Required" according to the CLA prep material for the CLA exam?
Yes, this is another "Jeff Question"!  Auto-pop does not work with "project templates"  so it definitively does not work as a *.lvproj base architecture. Sitting the CLA Exam I can use shipping examples of *.lvproj files but, NOT ones that contain "Auto-pop" folders?  HOLD IT
Yep HOLD IT! I said it TWICE!
Auto-populating folders do not work with "Project Templates".
Also the project explorer "views" quite definately define views on disc vs views on target.  FQN trumps location every time! (Just require a FQN!)
So, why require methods that cannot be implemented well?  Stop Auto-populating folders!  They were a bad invention that fixed the trouble with *.llbs.  Do not require that poor use as  a CLA test requirement.  [CAR# Requested]
And@ Tim I have my exam scheduled
"Should be" isn't "Is" -Jay
(5,126 Views)
Good Luck
(5,098 Views)
Finally!  How long have I been bugging you about that?  3-4 years?
(5,078 Views)
Hi Jeff,
Could you point me towards where this is in the prep material? I'm going to make a note to change that in our next revision.
Directory structure is graded on the CLA, but auto-populating folders are by no means required.
-N
Staff Certification Engineer
(5,074 Views)
@Nathanael wrote:
Hi Jeff,
-N
See section 2.b.2 on pg 5 of the prep guide
(5,066 Views)
Seems, that it's still there - I've dowloaded preparation materials couple weeks ago, and autopopulating folders are still listed in Project Organization and Hierarchy section...
(4,709 Views)
Those guides don't change overnight.  The clairification, and my feedback, have been noted by the appropriate NI team members and, I do not doubt that the change will be included in the next rev of the document.  It is probably not enough of a change to warrent an immediate revision.  Until then, Its documented here along with NI's official position on the issue.  (Another one of the great reasons why I strongly support this Board on the Forums!)
(4,662 Views)
