11-26-2012 09:44 PM
Hi folks,
I attached here, my first CLD ATM Controller attempt. Since its my first trial so i didnt do it in 4 hours took 6 hours to complete hopefully will complete other examples on time.So, please make a review, critiques and feedbacks are welcome for my further practice.
Attached same back saved with 2010.
Waiting for the replies.
11-27-2012 03:25 PM
A Couple quick points.
Discriptions and Tip strips on user controls should be considered mandatory.
Wire branches cause data copies get in the habit of wiring to the right SR node to avoid unnessecary buffer allocations as shown above
Why stop on error? the Close Ref does not care if error in is true it will try to close the refs. The loop is just silly too Close Ref works on arrays.
Why thisinstead of this? Merely changing the control ref type def to be a cluster of generic control refs lets you use the bundle to array. (as a matter of fact casting to more generic class would allow you to pass the refs as an array)
The timeout case is not the right way to exit. What if the dratted user keeps pressing the wrong button? the requirement is specific to exit in 10 seconds if the enter key is not pressed. use a timer that does not reset with user activity.
Overall nice
11-27-2012 08:15 PM
Many thanks jeff for reviewing my sample exam. The points you mentioned is exactly true, i really take seriously those comments and correct myself in the next examples.
Fun: Oh, Is there any option to give multiple kudos?
11-27-2012 09:57 PM
Jeff·Þ·Bohrer wrote:Wire branches cause data copies get in the habit of wiring to the right SR node to avoid unnessecary buffer allocations as shown above.
Dear jeff,
I can't get the SR node concept. Please any direction to help.
11-27-2012 10:29 PM
11-27-2012 10:52 PM
11-27-2012 11:32 PM
Yes jeff, I got you.
