BreakPoint
Wire managment hub
This is a wiring questions.  I have four wires that need to go to device 1, 2, and 3, i.e. all devices need equal access to the four wires.  I would like to build a hub that allow the 4 wires to go on one end and on the other end there would be 3 ports for device 1-3.  Any hub like device out there that I can use?
Message 1 of 12
(9,022 Views)
What would the hub be used with?  USB? Ethernet? others?
Message 2 of 12
(8,994 Views)
It would fall under others.  I am trying to improve my setup when we connect 3 power meter to a 4 wires com, to power (3 wires), etc.  Right now, the wires are connected to device 1 and daisy chain to the rest of them, but I want to get a hub that I can modify, so that I can use the star topology instead of daisy chaining.  The hub must be a really simple 1 to multiple devices without any logic instead.  Thanks!
Message 3 of 12
(8,969 Views)
GPIB?
-AK2DM
Message 4 of 12
(8,958 Views)
can you provide more details as to what the "wires" are or represent?  Is this part of an AC power / phase measurement?
We need more details, as it can be interpreted to be anything...
Message 5 of 12
(8,950 Views)
It is not GPIB.
Message 6 of 12
(8,904 Views)
@jyang72211 wrote:
It is not GPIB.
Well, glad that's settled. Only 5 billion other possibilities to go. Anyone want to guess first?
Message 7 of 12
(8,902 Views)
@jyang72211 wrote:
I have four wires... all devices need equal access to the four wires... I would like to build a hub that allow the 4 wires to go on one end ... I can use the star topology... The hub must be a really simple 1 to multiple devices without any logic instead.  Thanks!
You've got options here - red, yellow, blue, grey...
Message 8 of 12
(8,893 Views)
Sorry all.  Let me clarify a little.  I have a 3 wires from a RS-485, and I have 3 wires from power (hot, ground, shield).  I have multiple devices that need all these wires.  At the moment, I am daisy chaining them, but I am wondering is there a hub out there that would allow me to change the daisy chain into a star topology.
Message 9 of 12
(8,890 Views)
Message 10 of 12
(8,881 Views)
