BreakPoint
Rube Goldberg Code
Actually Ray.R version didn't work in 8.6 but doing Darin way did.
Regards
Ray Farmer
Message 891 of 2,635
(12,274 Views)
Thanks Darin for fixing my Rube... 😄
I should have known better!
(what was I thinking????)
RayF,
That is strange...  Why would it not work in LV8.6?  Did you set the Search & Replace to "Regular Expression"?
Message 892 of 2,635
(12,261 Views)
Ray.R,
Yep
Regards
Ray Farmer
Message 893 of 2,635
(12,250 Views)
I have access to LV8.6, so I will try it.. Maybe a bug...??
Message 894 of 2,635
(12,227 Views)
A bug?!! That is what you call your devious code-obfuscation?  To the untrained eye it would appear that you are checking the offset past replacements which would be -1 in the case of no replacements.  No, I'll wager that the wire is actually connected to the Number of Replacements which is indeed zero when the search string is not found.  I don't even feel the need to boot LV to check my guess.
Rubes and obfuscation, throw a local variable or two in there why don't you?  Smiley Very Happy
Spoiler
Prepared to eat my hat if I am wrong, but I am never not wrong.
Message 895 of 2,635
(12,189 Views)
Darin, what would I do without you?? 😉
Glad that one of us is never wrong.  Sorry about the obfuscated code.
I thought there was a bug in my code, not in LabVIEW 😄
Guess I was having a bad day   LOL!  😉
Message 896 of 2,635
(12,180 Views)
Nasty Darin!... Gosh, I'm glad I am never in error!
Smiley Sad
Spoiler
OK .... I sometimes make a mistake----
"Should be" isn't "Is" -Jay
Message 897 of 2,635
(12,164 Views)
If you post code to a thread designed for some hopefully good-natured mocking of others, it is hardly unreasonable to expect a little good-natured mocking in return....
Message 898 of 2,635
(12,160 Views)
that's what keeps this thread fun.
Just making sure you don't run out of supplies 😄
Message 899 of 2,635
(12,148 Views)
Can you spot the unecessary code complications on the left?
(seen here, this is only the tip of the iceberg! 🐵
  • We use a while loop as a FOR loop
  • With every itereation we create the entire ramp from scratch*, then index out one element
  • to get the wait time, we multiply it by 1000, then divide it by 1000 to get the original value.
  • We increment a counter in a shift register instead of using [i]
On the right would be an equivalent code alternative... 😄
* Of course the loop invariant code handling on the compiler might sort some of the problems out, but still.....
Message 900 of 2,635
(12,058 Views)
