BreakPoint
Rube Goldberg Code
Seen here:
https://decibel.ni.com/content/docs/DOC-13641
Is it really too much to ask that the NI developers writing these functions actually LOOK at the comparisson palette when they open it?
Come on - really!! - makes you wonder what the dll is like inside doesn't it?
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 901 of 2,635
(11,578 Views)
What would possess somebody to take a simple scalar, turn it into an array with a single element, integrate the single element array using simpsons rule, then index out the single element at the end???
(Seen here)
Message 902 of 2,635
(11,486 Views)
I don't know what the top code does, but multiplying by 2 and then dividing by 30 also seems Rube'd... 😉
___________________
Try to take over the world!
Message 903 of 2,635
(11,473 Views)
You got me there! I simply did not want to multiply by typing  0.06666666666666666666666666666666666666666666666666... . 😄
(of course I could have divided by 15 instead).
(The weird simpson scaling is not appropriate for an array with a single element. A multiplication by 0.1 is probably what's really needed here)
Message 904 of 2,635
(11,469 Views)
Did I create a Rube Goldberg, or is there a better way of doing the following?
I want to extract the lower 16 bits of a number.
Ignore the extra indicator in the code snippet.  It is the residue of a probe while converting to snippet.
I am replacing the lower 16 bits with zeros and then taking the difference.  The result are the lower 16 bits.
It's been an extremely long week and my brain has slowed down.  I seem to recall that there was an easier way of doing this, but I just can't access those braincells.
Message 905 of 2,635
(11,425 Views)
yes, you did  RG
"Should be" isn't "Is" -Jay
Message 906 of 2,635
(11,414 Views)
You could also use the To Unsigned Word Integer (U16). You'd get a coercion dot to move up to I32, but in this case who cares.
Message 907 of 2,635
(11,408 Views)
a few ways to skin the cat
Message 908 of 2,635
(11,401 Views)
Yeah. I just assumed there was a reason for the indicator being an I32.
Ray: is there something more going on?
Message 909 of 2,635
(11,397 Views)
The problem with "split number" is the change from I32 to U16, changing the representation. Here's what I would do:
Message 910 of 2,635
(11,388 Views)
