Good Morning All,
I've been fighting a problem here where I can't seem to reinstall LabVIEW 7.1.1 RT on to a PXI-8195 controller. It was originally on there but after being directed by NI support to do a disk format through MAX I haven't found a way to get back to that point. The "target system" (PXI-8195) boots into safe mode (the dip switches are set to normal boot, as is the BIOS) and MAX sees it. When, in MAX, do an "install software" under the target's software selection, MAX presents me with a list of drivers it wants to download, but not LabVIEW RT. If a download of the drivers is attempted MAX protests that they are dependent on LabVIEW 7.1. I've removed and reinstalled LabVIEW 7.1 on the host computer, performed the 7.1.1 update and mass complied the LabVIEW directory. The NI AE tells me that the files listed under the "RT Images" are correct, but even after updating to MAX 4.0 this morning (at NI's suggestion) MAX still doesn't see LabVIEW as an option to install on the PXI-8195.
Help me Obi Wan, your my (mostly) only hope!
PutnamCertified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
