BreakPoint
*LabVIEW Challenge - Recreate Numeric Palette Without Numeric Palette*
I thought I would present a Challenge to all of you.
The Challenge: Replicate a numeric palette function
The Rules: None of the numeric palette can be used(with the exception of constants). No copying anyone elses diagrams. Rules are subject to change given reasonable cause.
To win: Must have the most replications falling within the rules.
This is out of the box thinking, it can be fun or just cause headaches.
Good luck!
Here is my example of multiplying.
Message 1 of 11
(10,115 Views)
Cute. So, why does the indicator say "x+y"???
(In order not to run out of memory too quickly, I would use U8, though.)
Message 2 of 11
(10,104 Views)
I must have put a + thinking it was an *. And you are right, I should change them to U8.
Message 3 of 11
(10,102 Views)
Could benefit from some bit twiddling, but took a slightly easier approach.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 11
(10,068 Views)
I went the more hardware bit addition way.  I also avoided the nasty arrays.
Message 5 of 11
(10,049 Views)
Nice, I like these.
Current leader board:
1. Yamaeda - 2
2. crossrulz - 1
Oh, did I mention I give Kudos to valid answers?
Message 6 of 11
(10,035 Views)
How's this?  Got a few limitations on some but they all work on at least positive integers.
--Using LV8.2, 8.6, 2009, 2012--
Message 7 of 11
(10,008 Views)
I will count most of them.
The ones box in green are good but not being counted because it does a function not included in numeric palette or its creating a given according to the rules. The red box means that it does not work or it includes an unexplained recreation.
So that brings you to 8 making you the leader thus far
Message 8 of 11
(10,002 Views)
Just assume he used his own Divide by 2 (which you already see) and give him the extra point
Message 9 of 11
(9,998 Views)
I must have thought it was a different number. I'll give him 9.
Message 10 of 11
(9,993 Views)
