BreakPoint
How to specify exponent format in cwGraph?d
I'm using LW/CVI 7.0 with the cwGraph ActiveX control from MS 7.0 under Windows XP.
I'm trying to display the Y-axis in scientific format, but I can't figure out how to specify the maximum exponent width.
Maybe an example will clarify what my problem is.
Let's say I have a tick with value 0.003234 on the Y-axis. I'd like it to display "3.234E-3" and not "3.234E-002" like it does.
Unfortunately I have lots of plots in the widget and even a 2 digits space gain would be fantastic.
I've tried different VB formats, but I'm more of a C guy, so I easily might have missed something.
Any help would be greatly appreciated.
Sincerely,
Viktor STARK
(5,785 Views)
The breakpoint is our social forum. You should probably post this over in the CVI forum: http://forums.ni.com/ni/board?board.id=180
Good luck! 🙂
(5,777 Views)
    This forum (the Breakpoint) is more of a social thread, rather than technical. To get a helpful technical response try reposting your question to the LabWINDOWS/CVI Forum where those with knowledge of LW/CVI lurk.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(5,777 Views)
Sorry about that. Meant to post this to the LW/CVI forum originally. I guess I should click slower...
Viktor STARK
(5,764 Views)
Looks like Altenbach and LV_Pro are concurrent parallel post processors
(5,753 Views)
