BreakPoint
Capture of 4 analog chanels, using one of them as a trigger
Hello there,
I posted a message a week or so ago about some issues I was having, and I seem to have sorted them out (which is great!). Thanks for the pointers.
So, I have one more quiery, and hopefully the last for a while. I've attatched a copy of part of the VI I'm working with. All it does is capture a user-specifiable number of analog input channels and write them to a data file. It does so quite nicely, and with no problems. So..
My requirement is that the actual capture of the input channels must occur only when a certain triggering voltage is met. This trigger will come from a Berkley Nucleonics 500A pulse generator box. The precise nature of how it might work I am not sure about because I'm a little unsure about what my equipment can do. I was thinking the trigger could be one of the input channels.. that would be great. My interface is an SCB-68 board. It is currently set up for 4 analog input channels (and 2 output channels), using BNC connectors.
I've been doing some digging to try to avoid spamming a new message, but haven't really got anywhere.. I'm a little concerned about whether my system will even allow something like this. Will I have to wire in (physically) some new channels into the SCB board? I read something about only digital edge triggering being possible. If I have to use a digital trigger, is there any way to use the current pulse generator..?
Again, any pointers are greatly appreciated. Regards,
mike
(4,956 Views)
    This forum (Breakpoint) is more a social one than a technical one. There are forums on this site devoted to the DAQ questions, LabVIEW, whatever, where you will probably get a much quicker answer to your questions. As this is a social one it isn't visited as often by as many people as the other ones.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,951 Views)
Hi there,
sorry about that... total mistake - i meant to post in the labview forum..!
(4,947 Views)
