BreakPoint
Bug Updates_March
Reported Here for # 185781 DAQmx 9.1 resolves:
CAR ID Summary
131966 Test panels in Traditional NI-DAQ not usable with certain hardware when NI-DAQmx is installed
170368 NI ENET 9163 does not enumerate again after connection is lost in static IP mode
185781 NI-DAQmx auto start doesn't automatically stop task when reference triggering is enabled
185787 NI PXI 6704 Traditional NI-DAQ error -10461 when NI-DAQmx 9.0.0 is installed
189387 Calling DAQ DLL with callbacks using C API in multiple threads causes DLL to not be able to be loaded
194117 NI USB-6210/6211/6215 doesn't throw error when setting terminal routes to use PFI 4-6 for CI tasks
191661 DAQmx Get Write Space Availble returns incorrect value for X Series
198928 Error 50150 using bridge offset nulling calibration and shunt calibration with multiple NI 9237 devices
197835 DAQmx Generate Counter Pulse Output disables menu
194962 Reference Trigger Type is greyed out in LabVIEW SignalExpress
SImilar to Monthly bugs.  Show Bugs resolved or work-arounds developed.  Link to the OP if possible-just a list discussions in owner thread
Message Edited by Jeff Bohrer on 03-18-2010 07:50 PM
"Should be" isn't "Is" -Jay
Message 1 of 1
(6,689 Views)
