Biomedical User Group Discussions
How to apply Root Mean Square Processing on an EMG Signal stored as a LVM file?
Greetings,
I've been working on my wireless EMG project, implemented using and Arduino(for A/D conversion) and Bluetooth technology. I have successfully received the data on the computer and save it to an LVM file for processing. I've attached a sample data from one of my tests. Now, how would I perform processing on it? I would first want to rectify the signal but I know I can do that by using the absolute value function.
More importantly, after the rectification, how would I perform the Root Mean Square processing on the rectified signal? I've also attached a PDF file which talks about EMG signals in general, the part about RMS is on page 27. I am not familiar with using arrays in LabView if that will be used here, and I am using Labview2010.
A sample file on how to implement the RMS processing would be most helpful. Thank you.
(9,567 Views)
Look in the Mathematics >> Probability & Statistics palette for Mean and RMS VIs.  You do not need to rectify before doing RMS.  The squaring part of the RMS caclulation has the same effect.
Your data has a large DC offset. You may want to subtract the mean before doing your other processing.
I sometimes think EMG community is lost in the 1950s.  Much of the description of the signal processing is based on doing it all in analog circuitry.
Lynn
(5,190 Views)
Hi ArvinB..
I try to do some rms on your signal, but it's still saved without time information..... (first column if full of 0)
anyway, to implement some rms:
signal processing -> wfm measure -> avg DC-RMS vi......
or just on the biomedical startup kit source code -> process & analysis ->  EMG -> emg - Average RMS vi
Try that.
(5,190 Views)
Definitely agree with Ramon
(5,190 Views)
Hello Ramon,
Sorry it took a while. I've attaced a signal with some time information here. Can you show me how to use the avg DC-RMS vi? I've also attached a VI that I use to open and do some processing on the file.
Thank you
(5,190 Views)
hi Arvin....
i did some implementation on your code.....
you could change the "rms window"... it's usually below 500ms
good luck.
(5,190 Views)
