11-21-2011 08:07 AM
Greetings,
I've been working on my wireless EMG project, implemented using and Arduino(for A/D conversion) and Bluetooth technology. I have successfully received the data on the computer and save it to an LVM file for processing. I've attached a sample data from one of my tests. Now, how would I perform processing on it? I would first want to rectify the signal but I know I can do that by using the absolute value function.
More importantly, after the rectification, how would I perform the Root Mean Square processing on the rectified signal? I've also attached a PDF file which talks about EMG signals in general, the part about RMS is on page 27. I am not familiar with using arrays in LabView if that will be used here, and I am using Labview2010.
A sample file on how to implement the RMS processing would be most helpful. Thank you.
11-21-2011 09:54 PM
Look in the Mathematics >> Probability & Statistics palette for Mean and RMS VIs. You do not need to rectify before doing RMS. The squaring part of the RMS caclulation has the same effect.
Your data has a large DC offset. You may want to subtract the mean before doing your other processing.
I sometimes think EMG community is lost in the 1950s. Much of the description of the signal processing is based on doing it all in analog circuitry.
Lynn
11-22-2011
04:43 AM
- last edited on
11-07-2024
09:35 AM
by
Content Cleaner
Hi ArvinB..
I try to do some rms on your signal, but it's still saved without time information..... (first column if full of 0)
anyway, to implement some rms:
signal processing -> wfm measure -> avg DC-RMS vi......
or just on the biomedical startup kit source code -> process & analysis -> EMG -> emg - Average RMS vi
Try that.
11-22-2011 07:21 PM
Definitely agree with Ramon
12-08-2011 12:27 AM
Hello Ramon,
Sorry it took a while. I've attaced a signal with some time information here. Can you show me how to use the avg DC-RMS vi? I've also attached a VI that I use to open and do some processing on the file.
Thank you
12-08-2011 07:31 AM
hi Arvin....
i did some implementation on your code.....
you could change the "rms window"... it's usually below 500ms
good luck.
