Big Physics
White Rabbit - Ethernet-based solution for sub-ns synchronization and deterministic, reliable data delivery
Presented at NI by Maciej Lipinski
Electronics Engineer Fellow at CERN, Co-chair of the High Accuracy sub-committee in the P1588 Working Group
Abstract:
White Rabbit is a project that aims to create an Ethernet-based network with low-latency, highly reliable, deterministic data delivery and network-wide, transparent, high-accuracy timing distribution. The White Rabbit Network is based on existing standards (IEEE 802.1, 802.3, IEEE 1588) and enables sub-nanosecond synchronization of thousands of devices spanning over several kilometers. Conceived as a next-generation control and timing system for Particle Accelerators such as those at CERN, it is rapidly finding new scientific and commercial applications. An ongoing effort attempts to include a White Rabbit extension to IEEE1588 into the standard. This presentation provides an overview of the White Rabbit project, its current developments and an ever-growing list of applications. A light-weight insight into time and data distribution in the White Rabbit network, as well as standardization efforts and WR-based systems at CERN are presented.
Jacob R. | Applications Engineer | National Instruments
Comments
Member eran
I wonder how it is realted to NI , NO NI HW was showen .
Jacob_R
NI Employee
Although this was meant to be mostly educational... PXIe and CompactRIO were mentioned as WR nodes. To learn how WR relates to NI read this article:
http://www.techdesignforums.com/blog/2014/08/09/labview-white-rabbit-distributed-real-time/
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
Are there any updates on NI-based WR support?  How does all this tie in with Time Sensitive Networking, I believe there is significant overlap.
Will NI be offering WR IP for FPGA cards in order to expand these horizons to general High-speed serial applications?
Contributors
