Automotive and Embedded Networks
write to CANdb
Hi
I am a customer of NI. Now I have a urgent problem. I import CANdb file to the Labview with “path”, and I want to write data to the db file. I use channel API send the message, and use “task write” to write the data, but the message can not be received by CANoe. I do not know why it is. Can you help me?
Regards
vivian
(6,216 Views)
What is the control value, does it matches your CAN setting? You can using example to have a try. LabVIEW -> help -> find examples Hardware Input and Output -> CAN -> Channel API -> Basic -> Single Sample Input.vi
(6,206 Views)
