Automotive and Embedded Networks
USB 6211
Can I use USB -6211 to be like a relay to turn ON and OFF the signal?  The signal ON/OFF should happen instantly like a relay, no ramping.
/Kawsy
(6,702 Views)
Hi mnk,
The USB-6211 will not quite work like a relay as there is no way of physical disconnecting its pins. However, if you simply wish to output signals ON (5V) and OFF (0V), you can do so by simply writing the appropriate value on the pins. Since this is an analog output, there will be some ramping at a very fine level. The specifications claim that we have a 5V/us slew rate, but this can vary depending on what load you connect this to. Examples on how to write to your analog output channels can be found in our LabView shipping examples.
Hardware Input and Output >> DAQmx >> Analog Generation >> Voltage >> Gen Voltage Update.vi.
I hope this helps,
S_Hong
S_Hong
(6,681 Views)
Thanks for the info.
(6,669 Views)
