Automotive and Embedded Networks
periodic transmit
This is similiar to a question that I asked NI but have not yet received a response on.  So let me confirm what I understand from this thread.
Using Frame API.
There is no seperate hardware buffer where periodic commands (more than one) are stored.
If I use the periodic commands, I can only have one periodic interval, not one for each command.
If I have a mix of periodic commands and one off commands, then I am tasked with building the periodic buffering in code.
To have an idea:
Periodic commands
Arb ID  Data      Interval
174      81 01     1.2S
178      01          1.2S
678      03  FF    10.0S
Then be able to insert one time commands into the stream as needed.
This is a duplicate of a post in 'switch to write CAN' but I did not think I would get good feedback if left there although the discussion is similar.
Paul
(3,819 Views)
Hi Paul,
I’m a little unclear what exactly your application needs to do, but as far as I understand it, wouldn’t the following work?
  • Create three periodic CAN objects for the three listed IDs with the listed period.
  • Use the Network Interface to intermittently transmit other/unregular CAN frames.
(see attached code)
-B2k
Message Edited by biker2000 on 10-14-2005 07:51 AM
(3,808 Views)
I will give it a go and see how it works.  This is my first app using CAN, so there is a lot to learn.  I appreciate you taking the time to show me this example.
Paul
Paul
(3,790 Views)
