Automotive and Embedded Networks
negavite response as error?
I am using Automotive Diagnostic Command Set, and control an ECU via UDS.
As the ECU sends a negative response (0x7F), the Diagnostic Service.vi returns an error code -8127. I don't find this code anywhere, and basically it is not important, as I get the response from the ECU in the "data out" array of the Diagnostic Service.vi.
So I have 2 questions:
1. What is the error code -8127?
2. Can I set up the diagnostics so that a negative response doesn't trigger an error?
Madottati
(5,821 Views)
Hi Madottati,
The error code -8127 is a user defined error code. As reminder, following code ranges are user defined: -8999 through -8000, 5000 through 9999 and 500,000 through 599,999
You can try to debug the VI and find out where the error code is generated or just ignore it.
Marc
(5,808 Views)
yes I found it out. The 127 corresponds to the 0x7F negative response, and the VI returns it as an error. I will handle it in my VI.
(5,806 Views)
