 Madottati
			Madottati
			04-27-2015 10:02 AM
I am using Automotive Diagnostic Command Set, and control an ECU via UDS.
As the ECU sends a negative response (0x7F), the Diagnostic Service.vi returns an error code -8127. I don't find this code anywhere, and basically it is not important, as I get the response from the ECU in the "data out" array of the Diagnostic Service.vi.
So I have 2 questions:
1. What is the error code -8127?
2. Can I set up the diagnostics so that a negative response doesn't trigger an error?
Madottati
 OEMa
			OEMa
			04-28-2015 02:52 AM
Hi Madottati,
The error code -8127 is a user defined error code. As reminder, following code ranges are user defined: -8999 through -8000, 5000 through 9999 and 500,000 through 599,999
You can try to debug the VI and find out where the error code is generated or just ignore it.
Marc
04-28-2015 02:56 AM
yes I found it out. The 127 corresponds to the 0x7F negative response, and the VI returns it as an error. I will handle it in my VI.
