Automotive and Embedded Networks
can bus
Im trying to aquire data from 2 CAN interfaces on same card, I've written this programme (see attached) which works most of the time but is prone to giving me the internal driver error -1074388990.
Is there any reason why the code would do this and can I improve the code so I dont get the error?
Many Thanks,
Tom
(6,143 Views)
Hello Tom,
please follow the steps in this Knowledge Base entry:
http://digital.ni.com/public.nsf/allkb/25A1726C45E10F48862568F700715733?OpenDocument
If you still see the same error, please post your NicanErr.txt file as described in the article.
Johannes
NI Germany 644838
(6,129 Views)
If you have at least LV 7.1 available you should install the newest NI-CAN driver 2.5.2. Your internal error is most likely related to an older driver version.
Besides you could try to run the get names and initialize functions for both ports sequentialy. That might help.
DirkW
(6,126 Views)
