Automotive and Embedded Networks
Why is my callback function continously called
Configuration:
I use the NICAN driver ver 2.3 to communicate with some devices over more CAN buses.
The application is developed with Visual C++ 6.0 and runs under Windows NT/2000/XP,
with an Intel Pentium 4 running at 2.8 GHz.
Four NICAN-PCI cards are installed, giving a total of eight CAN buses.
It seams not to matter, how many of the ports are connected and opened.
Problem:
Occasionaly my application is flooded with calls of the callback function.
Sometimes there are two short peeks of processor usage of 100% within 2-3 seconds, sometimes the processor usage remain at 100% until the port ist closed.
The problem seams to occur after a CAN bus is powered off, then powered on again.
The normal traffic on the lines is low - under 20 packets per second.
Code:
My callback function has nothing special.
It should be called only if data is available for read.
NCTYPE_STATE _NCFUNC_ NiCanCallback(NCTYPE_OBJH a_uiObjHandle, NCTYPE_STATE a_uiState, NCTYPE_STATUS a_iStatus, NCTYPE_ANY_P a_pRefData)
 NCTYPE_STATE  uiState = NC_ST_READ_AVAIL;
 CNiCanLibInterface* pNiCanLibInterface;
 CAN_FRM_DATA  lCanFrmData;
 // Typecast the pointer to appropriate type
 pNiCanLibInterface = (CNiCanLibInterface*)thePack.gHandleToPtr.Get(a_uiObjHandle);
 // If the data is available on the port
 if( pNiCanLibInterface != NULL && (a_uiState & NC_ST_READ_AVAIL))
   memset( &lCanFrmData, 0, sizeof(CAN_FRM_DATA) );
   lCanFrmData.m_nLineNo = pNiCanLibInterface->m_iPortNo;
   // Read the data from the port
   LRESULT lrRetValue = pNiCanLibInterface->ReadPort(pNiCanLibInterface->m_iPortNo, &lCanFrmData);
   if(lrRetValue == CAL_SUCCESS)
    // Post the data as a user message to the thread in which this DLL is mapped
    // VERY IMPORTANT: The thread should delete the data pointer which is passed as LPARAM
    thePack.m_pApi->m_pInputQueue->AddPointer( &lCanFrmData );
    if ( thePack.m_pApi->m_pCallerInfo->m_hReceiveEvent != NULL )
     SetEvent(thePack.m_pApi->m_pCallerInfo->m_hReceiveEvent);
 return uiState;
After the port is opened, a notification is created for reading:
  iStatus = (*m_pDriverInfo->m_pncAction)(m_uiObjHandler, NC_OP_START, NULL);
  if(iStatus == NC_SUCCESS)
   m_pChanelData->m_bIsStarted = TRUE;
   lrRetValue = CAL_SUCCESS;
   // Register the required events for notifications
   iStatus = (*m_pDriverInfo->m_pncCreateNotification)(m_uiObjHandler, NC_ST_READ_AVAIL, NC_DURATION_INFINITE, NULL, NiCanCallback);
    // Store the thread ID. The received data messages will be sent to this thread.
    m_dwThreadID = ::GetCurrentThreadId();
   else
    //Close previously opened port if m_pDriverInfo->m_pncCreateNotification function call fails
    ClosePort(m_iPortNo);
A sample of the NI Spy protocoll is attached.
The following message is continously repeated:
Invoking NI-CAN user callback (32376768, 1, 16546, 1073094668, 1),Prozess-ID: 0x00000AA0         Thread-ID: 0x00000C24,Startzeit: 10:22:58.502       Aufrufdauer: 00:00:00.000,Status: 0x3FF6200C,
Georg
(6,327 Views)
can you reproduce that also with our CAN examples like in my *.zip file ?
Best Regards
(6,317 Views)
Hi Johann,
Thanks for the samples.
I couldnt find an appropiate sample using notifications.
In my case a flood of notifications occur - all on channel 1 (which makes no sense), all with State 0x40A2
( NC_ST_WRITE_SUCCESS + NC_ST_WARNING + 0x80 ??? + 0x4000 ??? )
although my call back function was not registered for NC_ST_WRITE_SUCCESS, but only for NC_ST_READ_AVAIL.
I wander what the other bits could mean 0x80 and 0x4000.
I suppose that is has something to do with the Warning Bit.
I do not know how to supress notifications on warnings.
Have someone some idea?
Georg
Georg
(6,313 Views)
Do you tried the actual NI CAN driver 2.5.2 ?
https://www.ni.com/en/support/downloads/drivers/download.ni-can.html#344623
Perhaps you have here no problem. Please try it when possible.
Best Regards
(6,251 Views)
