10-05-2025 01:14 AM
Hi everyone,
I'm currently using the NI-XNET Bus Monitor to observe CAN communication between two systems. While I can successfully see the messages being received, I'm unable to view the messages that are being transmitted from one system to the other.
Has anyone encountered this issue before? Are there specific settings or filters that need to be configured to view transmitted messages? Any guidance or troubleshooting tips would be greatly appreciated.
Thanks in advance!
10-05-2025 08:55 PM
Under Interface and Database Settings, enable Log Transmitted Frames.
You might want to set the Run Mode to Subordinate.
10-08-2025 07:23 AM - edited 10-08-2025 07:32 AM
Hi @Mapwar96,
This issue has come up in several threads and is often related to session configuration, filtering, or hardware setup. Here are a few things to check:
Configuration & Filtering
Hardware & Bus Setup
Let me know if you’d like help reviewing your session setup or if you can share a screenshot of your Bus Monitor configuration.
