Automotive and Embedded Networks
取消
显示结果
搜索替代
您的意思是:
Suddenly "Memory Resource Conflict" was happened, How can I solve it?
I used PCMCIA-CAN card as usual, but suddenly the card stop.
And I tried self-test on PCMCIA0CAN Measurement & Automation Explorer, but the self-test failed and memory resource conflict was reported.
Then I checked conflict on device manager of Windows XP, but no conflict for memory and also interrupt.
There is a website which explain how to solve this kinds of error, and I tried the solution explained here. But I have still the problem.
[link removed]
Also, PCMCIA0CAN Measurement & Automation Explorer shows hardware series of the card is 1, but I am using PCMCIA-CAN series2.
Could you please let me know how to solve the problem?
Early answer will be highly appreciated.
Thank you for your help in advance.
いつもどおりPCMCIA-CAN のカードをつかっていたら、急にカードが動かなくなりました。
PCMCIA0CAN Measurement & Automation ExplorerでSelfTestをしたのですが、失敗しmemory resource conflictと表示されました。
そこで、WindowsXPのデバイスマネージャでConflictをチェックしたのですが、メモリーも割り込みも問題ありませんでした。
上記のWebにこの種の問題の解決方法が載っていたので、試してみたのですがだめです。
私が使っているカードはPCMCIA-CANのシリーズ2なのですが、PCMCIA0CAN Measurement & Automation ExplorerのHardwareSeriesは1になっています。
どうやって問題を解決したらよいのかを教えてください。
早めの対応をお願いします。
0 项奖励
1 条消息(共 5 条)
5,210 次查看
Truy the following :
1. remove the board from your PCMCIA carrier. ands close all NI software. (MAX, LabVIEW, CVI...)
2. uninstall the NI-CAN driver and reboot your machine.
3. Install the newest NI-CAN driver 2.4 from here  and reboot again.
4. insert your board again and check in MAX for the board.
Please post your results to this thread.
DirkW
0 项奖励
2 条消息(共 5 条)
5,193 次查看
Dear DirkW,
Thank you for your advice.
The problem was resolved and now everything is working.
By the way, Is this a problem of occurring frequently?
It is troublesome if the problem often occurs. For example, weekly or monthly.
Miyako
0 项奖励
3 条消息(共 5 条)
5,181 次查看
Hopefully this was an problem of the underlaying service software for the PCMCIA hardware. We changed to a new version for this software with NI CAN 2.4 and you should not face this problem anymore.
DirkW
0 项奖励
4 条消息(共 5 条)
5,170 次查看
Thank you for you reply. I feel relieved.
Miyako
0 项奖励
5 条消息(共 5 条)
5,163 次查看
