Automotive and Embedded Networks
PCMCIA CAN/2 und DIADEM
Hello Everyone,
can anyone tell me if the PCMCIA CAN/2 is directly supported by Diadem / Max WITHOUT the use of external drivers (ie Vector db files)?
Thanks, Jeff
(5,282 Views)
Hello Jeff,
the only thing you need is the NI_CAN driver for your device. Then install the driver, put in the device, go to MAX and make a channel list. Start DIAdem, got to DAC module. There you will find a CAN block. in it you can load the CAN channels and work with it.
Hope this helps,
Rebecca Fox
Applications Engineer
(5,276 Views)
Thanks for the quick reply!
Jeff
(5,269 Views)
