PCI-CAN/XS2 Single wire configuration
778782-02  NI PCI-CAN/XS2, 2-Port, SW Select, 9-Pin DSUB
I am trying to communicate to a GM Module.
Currently we use a PCMCIA Vector product and a I+me Actia CAT tool.
We purchased several 778782-02  NI PCI-CAN/XS2,
What is required is configuration for single wire can.
Then send a High voltage wakeup then normal CAN communication.
Using the supplied information and the examples it appears
like my commands are mixed between Channel and Frame.
The examples I received use the NC_xxx commands but all of the examples are for 2 wire CAN.
Is there an example where I can
Set the Can0 to single wire
Configure for 33.33K Baud
and Send a high voltage Wakeup Command.
Is this all in the Frame mode NC_
Do I mix the NC_ with the NCT_
(4,250 Views)
it seems you mixed Network Interface configuration and object open. But as far as i can see there is no channel api  in your code.
You have to open a port handle in order to set the transceiver type . Therefore the start on open attribute needs to be FALSE and you need a nc action to start communication after setting the attribute.
I modified the standart example and you can run it on a XS board with both ports cabled together.
hope that helps
(4,233 Views)
