Automotive and Embedded Networks
NI-9402 I2C Reading Erroneously from a Sensor
Hello Amy4082001,
If the CH0 is having this behavior, it's likely to be a hardware problem and might need to be sent for repair. Please, open a Service Request for handling this
PedroR
Message 11 of 13
(941 Views)
Thanks, I'll do just that.
Message 12 of 13
(939 Views)
Accepted by topic author Amy4082001
Hello Brian et al,
I figured out the solution to the erroneously/noisy/shifted sensor output.  Basically, I needed to provide adequate WAIT times for the I2C read.  I was providing WAIT times, but it wasn't enough, and apparently, the WAIT times for the 1st sensor is different than the other 3 sensors (IDK why).
I've attached the image of my block diagram and I highlighted where, in this loop, I provided this WAIT time.  I am also attaching my Labview code so if other people want to use the NI-9402 as an I2C module, they don't have to go through the pain of figuring out how it works.
For my system, I'm using the NI-9402 as an I2C module to talk to four MC3672 sensors.  Then, I'm calling my NI-9402 code in my cRIO-9039 environment to sync with some motors that I'm running.
Message 13 of 13
(925 Views)
