取消
显示结果
搜索替代
您的意思是:
NI-9402 I2C Reading Erroneously from a Sensor
已解决!
转到解答
Hello Amy4082001,
If the CH0 is having this behavior, it's likely to be a hardware problem and might need to be sent for repair. Please, open a Service Request for handling this
PedroR
0 项奖励
11 条消息(共 13 条)
979 次查看
Thanks, I'll do just that.
0 项奖励
12 条消息(共 13 条)
977 次查看
解答
已被主题作者 Amy4082001 接受
Hello Brian et al,
I figured out the solution to the erroneously/noisy/shifted sensor output.  Basically, I needed to provide adequate WAIT times for the I2C read.  I was providing WAIT times, but it wasn't enough, and apparently, the WAIT times for the 1st sensor is different than the other 3 sensors (IDK why).
I've attached the image of my block diagram and I highlighted where, in this loop, I provided this WAIT time.  I am also attaching my Labview code so if other people want to use the NI-9402 as an I2C module, they don't have to go through the pain of figuring out how it works.
For my system, I'm using the NI-9402 as an I2C module to talk to four MC3672 sensors.  Then, I'm calling my NI-9402 code in my cRIO-9039 environment to sync with some motors that I'm running.
0 项奖励
13 条消息(共 13 条)
963 次查看
