Automotive and Embedded Networks
LIN Wake-up
Hi there,
I've got a PXI-8516 LIN Modul (XNET) and want to use it as a Master. A Slave is connected to it. I put the master into sleep mode. If the slave has new messages for the master it initiates a wake-up, but the master will not wake-up. I have checked the wake-up pattern and it was 260us. Has anybody an idea why it didn't work? Is the wake-up pulse to short? According LIN spec. it should be ok (250us - 5ms).
greets
Thomas
Message 1 of 11
(8,152 Views)
which module do you use as slave?
regards,
Maxi
Message 2 of 11
(8,130 Views)
the Slave is build by our own. It is a rf-receiver which has a NXP TJA1028 LIN transceiver.
greets
Thomas
Message 3 of 11
(8,124 Views)
Hey Thomas,
have you already noticed the example in LabVIEW?
It's named 'LIN Master Control Sleep-Wakeup.vi'. Maybe that helps for your issue.
It also would be great, when you could send us your VI.
Maxi
Message 4 of 11
(8,090 Views)
Hi Maxi,
I'm already using this VI ('LIN Master Control Sleep-Wakeup.vi') to test if the master will wakeup from the wakeup impulse from the slave. But it didn't work as I mentioned.
greets
Thomas
Message 5 of 11
(8,084 Views)
Hi Thomas,
when you run the VI and try to wake up the master, does an error occur?
Or is the master simply in sleep mode until you stop the VI?
Maxi
Message 6 of 11
(8,051 Views)
Hi Maxi,
the master is still in sleep mode until I stop the VI. If I checked the "Wait on slave" (I don't know how it is called at the moment) Checkbox after I put the master to sleep mode then a error will occured that the slave didn't wake up the master within the specific time.
Additionally I have connected PORT 1 and 2 together to check if a NI LIN Module will wakeup each other, so this worked. The wakep up impulse was much longer than from the NXP LIN Transceiver.
Regards
Thomas
Message 7 of 11
(8,036 Views)
hi,
    I also have the Lin wake up issue, i use NI-LIN 8476 with the sample VI "LIN Master Send full frame and Receive.vi", some time can wake up the DUT, sometimes can not.I set LIN sleep attribute to true, still have the problem. change the IsRemote to 16,17,18, it doesn't work.
   Any one can help?
Message 8 of 11
(6,001 Views)
IS there anyone from NI can answer my question????????????????????????????????????????????????
NI LIN card is really confusing
Message 9 of 11
(5,985 Views)
You waited one day before bumping your post, and you originally posted on a sunday.  Most people on the forums are volunteers and if you need immediate help contact NI support.
Message 10 of 11
(5,977 Views)
