Error 8701 - Close Message table.vi in NI CAN
I wrote a program that reads the CAN data from sensor using NI CAN frame API. Then I used Frame to Channel Conversation API to converts the raw data into actual physical values using a database file. The code works well but the only problem is when I press the stop button to exit while loop Labview shows
"error 8701 at Close Message Table.vi occured
Possible reasons: The table handle you have passed is invalid. the table handles must first be created by create message table.vi "
I did it in same way but then also I have this error. Can anyone help me????
Please see the snapshot.
Thanks in advance
(6,125 Views)
It is possible, that this is no LabVIEW error. Have you tried your program with another computer?
Error 8701:
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (8701) or for its hexadecimal representation (0x000021FD).
Greetings, Lisl
(6,023 Views)
Hi Lisl,
Thanks for the reply. I solved the problem. The error occured because I created one message table and closed it twice.
regards,
swap
(6,016 Views)
